new max s with the rear shelf on hinge that  cannot be lifted open. Wood edge raise a 1/2 inch in the center but is tight towards the sides. Any thoughts on getting it open? I guess the remove the screws that connect it to the hinge but putting those back look nasty.
                0 ·
I will someday saw my hinged shelf into 3 parts to match the braces in the storage area so that the entire thing doesn't have to be raised to access the area and will correct the length issue at that time.
