You got it. Yes, before the Alde they had two heating systems to be used on or off shore power.JackPack said:OK, this might fall under the category of DUH.
2012 Max Q has a furnace, and it has a Dometic "Cool Cat" heat pump (model is 441003.701). That'd be two different heating systems, right? If true, is it so that when connected to shore power, you're not burning propane when heating the trailer?
