The sliding screen door in our 2016 Tab is getting stuck at the bottom and requires a careful two-handed operation to get it to open and close. We are considering using grease or oil or something else (baby powder?) in the track to ease it up. Has anyone had to do this on theirs and what did you use?
Thanks in advance.
Tommy
0 ·
Not sure I'd use a liquid lube - Would attract dirt.
@jkjenn after seeing a multitude of other factory misalignments it wouldn't surprise me a bit - I'm not knocking T@b - we love it to death - but I could make a list of workmanship issues. Not nit-picky stuff - big stuff like the LP/Battery box was badly off center and crooked. I've already taken it off and fixed it and also fixed the position of the plastic battery box - they plunked it down right in the middle and badly crooked. The next thing I have to fix is the water pump hatch in the bathroom absolutely will not latch no matter how hard we press on it. It hinges at the top and latches at the bottom and with the rubber seals as fresh as they are the resting position of the hatch is 1.5 inches open - which causes the toilet lid and seat to not stay in the open position. It feels like we got the one from the very end of a production run when everyone was tired and rushing to get through with it haha. Anyway, joys of owning a trailer I guess.
Because it pretty much thoroughly soaked the track, I would bet that you have dust or sand that has accumulated in the track. I used folded paper towels and Q-tips to clean the track out (lots of sand and dirt after camping for 3 months in AZ).
This is 100% correct. The propane box is shipped inside of the T@b and the dealer installs.
jkjenn said:Good to know @jkjenn thanks. We bought a new/used unit without a warranty. Someone had bought it new and traded it back in apparently without using it. I took the entire hatch out this morning and have repaired it. Part of the problem was whoever installed it misaligned the metal tab that the latch clicks on to. It was installed about a half of an inch off center to the latch.
Thank you @Verna we will definitely not "accidentally" spill soup on it
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Durango, CO
2015 S Outback
