I know I've seen someone on here do it before, but can't seem to search the post down.  I have an outback platform and it's a pain to get to the black & gray water discharges to hook up the hose.  Do they make extenders or does someone have some diy photos?
                2016 T@B silver Sofitel/Outback combo, 2012 Jeep Wrangler Sport TV, Kernersville N.C.
0 ·
There's no room to actually raise it on ours, but It seems that just moving the gray valve back would help, toward the gray tank (and away from the hitch), closer to the area of the black discharge, .
Could use a quick-disconnect on a solid-pipe extension, which could be stuck on there when it's needed, so it doesn't hang down all the time. The gray valve handle's clearance is a consideration then, being sure that it clears the black drain.
Valterra makes an adapter, in 3" threaded pipe:
Watch out though, the gray water pipe is 1½" on ours, not 2"...
South Carolina
South Carolina
South Carolina
