trailer coupler height
KYkampersKYkampers Member Posts: 19
Can anyone tell me the range of hitch coupler height for a 2015 S Maxx?  I want to get the proper ball mount.
    16" top of ball as I recall.
    Yup, top of the ball should be 16" from the ground.
    Sterling, VA
    Yep, 16" is supposed to put the trailer at level, which is ideal for towing.  I have had to make some adjustments to mine over time.  I moved the spare tire to the tongue and added a heavier duty battery.  I also tend to overload the back of the truck with just-in-case stuff.  The result has been that the original 16" height got a little lower.  I noticed a difference in towing.  I have raised the ball a little by adding a couple of huge split washers and added just a little weight to the back of the trailer.  Will give the new setup a test on the way to Tearstock.  If it doesn't work, adjustments will be easy.
    Happy Trails Y'all
    States Visited Map
