 sabel
                    Member Posts: 283
sabel
                    Member Posts: 283
            More advice needed,
We currently tow our Little Guy with a 2" ball hitch. Our vehicle's owner manual ( 2011 Toyota 4 Runner ) requires a load distribution hitch ( LDH ) for trailers with a GVWR of over 2000 lb. Does anyone here with a T@B use a LDH? T@B specs show their dry weight is about 1700 lbs. while GVWR is about 2800 lbs.
That means payload is about 1100 lbs. That's a lot of stuff.
Thanks
place to get answers for these hitches. They do have an on-line chat or their phone number is listed on their website. Please tell us what you find out. Good luck.
Here's a response to my question from etrailer.com.
Thank you for asking the following question:
We currently tow a Little Guy trailer very small tear trailer GVRW is about 1000 lbs. with a 2inch ball hitch. Tow Vehicle is a 2011 Toyota 4 Runner with a tow capacity of 5000 lbs and tongue weight of 500 lbs.
Were considering buying a bigger T@B trailer with a GVWR of about 2800 lbs. T@B dry weight will be about 1700 lbs. Do you think we will need a load distributing/sway hitch? Toyota owners manual states to use one if trailer exceeds 2000 lbs. If you recommend one which hitch would you recommend
You asked a great question, so I made an answer page for you with additional information. You can see it here:
http://www.etrailer.com/
If you have any other questions please call 1-800-298-8924 to speak to one of our Customer Service representatives.
Thank You,
Jameson C
