How hot is the hot water that the Alde produces?
I have the mixing valve, the one next to the Alde boiler under the rear seat, turned to maximum, propane and electricity selected and the menu setting at max water temp.
The water starts out really hot, then cools to what I would call warm.
Thanks
                0 ·
Keep in mind that the Alde's hot water tank is small (<3 gallons), and what you draw off will immediately be replaced with cold water that will temporarily lower the temperature in the tank, and cause the water coming from the tap to get progressively cooler as more is drawn off.
Note that I have a 2015 S with the analog (slider) Alde controls and no mixing valve. The digital controls may have different operating parameters, and the mixing valve (not to mention the temperature of the incoming cold water) can also have an influence. I vaguely recall at least one issue someone had with a faulty mixing valve--perhaps someone experienced with those upgrades will chime in with more info.
After adjusting the mixing valve on my 2017 T@B Max S, I have sufficient hot water.
Going on it looks like not all mixing valves are like mine and some T@Bs don't have mixing valves.
Will be interesting to see what those that dig into these details come up with :-)
This is how I fill my fresh water tank.
When the Alde unit is turned on via the digital thermostat you do need to program it for the hot water tank setting and it takes approximately 15 minutes to have hot water via the 2.5 gallon hot water tank (as I recall) in the Alde. Be careful as the water is very hot and can scauld skin if you don't use care and mix it with some cold water.
