We're planning a weekend trip up in the mountains but have never filled the fresh water tank until we get up there. Takes a lot of bucket trips to fill the tank from a camp site. I'm considering filling the tank at home first but am a little concerned about the extra load.
Does anyone else travel with a full load of water? If so, any issues?
Thanks
                0 ·
Trailer Sway Causes
Now that we have some of the common terminology out of the way let's talk about the typical causes of trailer sway. Keep in mind that trailer sway is a multivariate condition. Any one of these causes may not cause a trailer to sway. However, when more than one of these causes is present, a trailer is sure to begin to sway unless acted upon by an opposing force.
Towing Speed - Typical highway speeds have become much greater over the last 50 years. The speed at which you decide to tow your trailer may be the single greatest factor in controlling trailer sway. Unfortunately, tests show that any speeds greater than 45mph tend to allow almost any trailer to begin to sway. With traffic traveling at much greater speeds it isn't practical, and most of the time illegal, to travel at a speed that will control trailer sway.
High Winds - Winds blowing perpendicular against the side of a towed trailer push the trailer and pivot it on the hitch ball creating a tow angle. The greater the surface area of the side of the trailer, the greater the force will be at any given wind velocity. Towing in high winds is never a good idea and should be done cautiously if necessary.
Gusting Winds - Winds can gust and increase in velocity due to weather. Winds can also be described as gusting when a high wind is blocked by a tree line or a bridge overpass and you clear this blockage while towing. Your trailer goes from a relative low side force to much higher side force that pivots the trailer on the hitch ball and creates a tow angle.
Bow Wave - A bow wave is a wind produced by a large semi-truck, box truck or van pushing its way through the air on the highway. This wind travels around the truck and down the sides creating a wind disturbance in the adjacent lanes. This wind disturbance creates a sudden high to low pressure in the air traveling down the side of your trailer. The bow wave, as with the other wind disturbances, creates a tow angle by pushing the trailer and pivoting it on the hitch ball. The bow wave produces a "sucking" feeling in some combinations that feels like the entire tow combination is being pulled into the other lane.
Bad Roads - With any type of travel across this great country you'll realize there are quite a few roads that need work. These uneven, poor roads can make a trailer become unbalanced and cause it to pivot on the hitch ball creating a tow angle.
Downhill Travel - Towing downhill can allow your trailer to roll faster than the tow vehicle. The tow vehicle is geared to slow down when you let your foot off the accelerator. However, trailers are not equipped with this feature. When the trailer is traveling at a higher rate of speed than the tow vehicle it can begin to yaw.
Poor Trailer Design - The fact is that some trailers are designed better for towing than others. Trailer design includes a lot of different variables that need to be addressed to properly balance the trailer for towing. Even with a good trailer design the designer can have a hard time determining what the optimal layout of the trailer should be because of the added dimension of the trailer being used by so many different customers.
Improper Loading - Trailers are very sensitive to where you place your load your cargo. Your black and gray water tanks, your supplies, your clothing and anything else you carry with you will change the weight of the trailer and how that weight is distributed throughout your towed combination.
Poor Weight Distribution Hitch Adjustment - When a weight distribution hitch is not adjusted properly it can cause your trailer to have either too much tongue weight or not enough tongue weight to avoid inducing sway.
I did not encounter sway. I just attributed it to improperly distributed weight.
2016 T@B Q ~
2015 Jeep Cherokee Trailhawk
It'll be a short ride for us so I might partially fill the tank as a "science experiment".
Short ride but lots of switchbacks and steep grades as you know.
Wonder how many other T@Bs are in the Big Horn area?
2016 T@B Q ~
Chesterfield, VA
Happy Trails Y'all
As a matter of practice, I always fill my tank before I leave on a trip. It adds 88 lbs and doesn't do anything to my gas mileage (big pickup) and I don't have sway.
I have encountered "iffy" water at state parks. Not just odors, but tags saying to not the drink the water because of microbial contamination on various water spouts where the tags have been put there and obviously ripped off (I can't rem the park's name, sorry). My water filter will not take care of heavy microbial contamination. It's meant for particulate matter, off taste and odors.
PS As a crazy mad scientist and microbiologist, I'm paranoid. Also keep in mind I have a compromised immune system due to a chronic illness, so I'm extra careful. YMMV.
One concern I would have when we discuss sway is having a less than full tank and no tank baffling, allowing the water to slosh around. I haven't tried it and it may not be enough weight shifting around to matter; has anyone seen issues with this?
The newer T@B's have the fresh water tank under the unit, between the axle and the floor. It is larger and runs the length of the floor. I don't know how it would affect towing beyond simply adding more weight.
Sterling, VA
