Did you need to pull the Jensen or does it pop out from the frontPXLated said:That's weird... You could call Ed and have him send you a new outlet - Mine was totally dead. It was very easy to replace.
Did your dealer replace it? Not sure I trust mine with wiring...ericnliz said:I just had to have the one in the galley replaced also. 2016 S Max The cigar lighter port worked, but the USB port did not on either port.
Mine wasn't working either and all appeared "good" when I dropped the wires down - but when I wiggled the red one (while I had iTouch plugged in), the connection came on and would go off when I moved the wire. I found those blue splice connectors and replaced the one to the red wire - now it works.Photomom said:Yep, it is hanging down at the moment and all wires appear to be connected. Shooting off an email to Ed - hopefully he will just send me one...
Just need to find a few minutes to hook it up!
