Microwave installation
I have a Sofitel Max S on order with factory pickup.  The one handy thing that is missing is a microwave (only $29 from Walmart).  Would like to give the factory a little challenge to install a small .7 microwave (17.30x13.40x10.20) under the sink or replace the middle cabinet in the rear.  The mount I guess would be similar to the AC.
Since I don't have a unit to measure and/or determine functionality, any ideas or suggestions would be helpful as I work with factory on this.
Plano TX, 2017 T@B S Max Sofitel, 2017 Honda Ridgeline
  • Tabaz Tabaz Member Posts: 2,414
    I have the Westinghouse 700W countertop model.  It's approximate dimensions are 18" wide x 10" tall x 11" deep (up to the door seal.  14" deep with the door handle).  It weighs 21 pounds.  You'll need a 110V outlet nearby for the cord.  You'll also need an inverter if you plan on using it off-grid.  This microwave actual pulls 900W while running.
