Battery shut off switch
chuckshaver
Member Posts: 23
What switch do you use?
Can you be a little more explicit? There are several threads here, but your question was kind of vague to give a good answer. What trailer do you have, year& model, and what type of battery set-up?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I want to put in an on off switch in the wiring between the fuse and battery.
the set up is the standard 12V RV battery in the front shroud.1
Nice, thanks.0
Thanks for helping ScottG!2016 T@B MAX S-aka: WolfT@B
Simple, safe, and very rugged. Also easy to install at the battery. Two models available to fit different types of battery posts.2016 Outback.....North East N.C...... Former 2012 Silver Shadow0 -
This is the new Perko switch (made in the USA) I recently installed in the tub of my trailer. Keep in mind that this switch is much larger than the smaller Marinco switch shown, but it appears to be well made, is a sealed unit and heavy duty. If you were to make a circle with both hands, that is about the side of the switch housing but this doesn't deter me any as it is doing the job thus far.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
JustJohn - Like the simplicity of that and it looks fairly fail proof. Of course, I don't need one, my battery's never off :-)0
JustJohn, I use that same one. Been great so far....knock on wood!Stancil Campbell
2011 T@B
Rockingham, NC
