"Free" Dump Station Locations - List by state please!
Michigan_Mike
Member Posts: 2,858
This discussion was created from comments split from: Why do some states have/allow tank dumping at rest stops and others do not?.
Maybe we should start a new thread - rest stops with dump stations...
When traveling on Interstate 5 through the Willows area in northern CA, the rest stops there north and south directions have a dump station located at the exit to get back on the freeway. This is the only one we've found so far.
Great - thanks @Michigan_Mike we will add to this every chance we get.
The Allstays app shows rest stops. If you click on the symbol it tells you if it has a dump station or not. It also shows where other dump stations are (truck stops, municiples, etc.)
Hit a SD rest stop a few miles west of Wall, SD last week - Very nice, clean DS with potable water also.
Tacomaguy - My go to app for campgrounds is UltimateCG - tends to show more federal and boondocking sites but Allstays is my go to for services, road grades, etc.
Good information and I wasn't aware that the app provided that feature. I will be checking this out the next time I need to dump! Thanks!PXLated said:The Allstays app shows rest stops. If you click on the symbol it tells you if it has a dump station or not. It also shows where other dump stations are (truck stops, municiples, etc.)Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ -
On I-80: OH (every other rest area), Some in IA and NE. In CO check the welcome centers. The one on I-76 at the NE border has one.
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
