Question about the mixer valve
Photomom
Member Posts: 2,217
The valve is only labeled + and -. What does that mean? If I turn it towards + does that give me more hot water, or more cold water mixed in with the hot?
I've played with the valve but the results were inconclusive.
Towards the + side is for hotter, the - side cooler. I know, I had to play with mine also.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
Thanks for the info. I think I inadvertently set it for cooler water assuming the - was for less cold water in the mix...Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
Yeah since it is a mixing valve one could assume the + means more mixing.John and Henrietta, Late 2016 T@B S Max in Western New York
- 919 Introductions
- 74 Teardrop Groups & Links
