Generator
Trailsnail
Member Posts: 21
used generator today Yamaha 2000 no power to outlets. Checked breaker fuses all good. Any ideas?
Describe your setup - A 110 adapter at the gen into your 30amp cord that's plugged into the T@B?
Is there power coming out the 30amp cord for sure? I had a bad adapter, took me awhile to figure that out.
Not sure. Adapter is good have plugged into house and red light was on but not today.
Meant to say not sure if adapter is good or not tried it alone and with extention cord into 110 on gen
If the red light isn't coming on, it could be the adapter.
You might need a loopback plug if you are using a surge protector - take off the surge protector and see if you get power. Make sure all electrical items are off before you plug in without the surge protector. There is also a reset button on the generator when you use too much power and flip the breaker. My Honda resets after so many minutes (can't rem how long).2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
Also check the reset button on the interior 110v outlets. I believe they are wired in "series" wherein if the first one pops, it takes out all the others.2016 Outback 320
And check the ground fault button on the interior outlet.
PXL is correct - check the ground fault button. Any time I do anything electrical with the T@B, the GFI has a tendency to trip.2016 Outback 320
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
