Removing TV from kitchen area in CS
gailshamberg
Member Posts: 2
Has anyone removed the TV from the clamshell kitchen area of a 2016 T@B Sofitel (Max)? I want to take it out and put in a spice shelf, but cannot figure out how to remove the TV from the bracket, or the bracket from the wood wall separating the kitchen from the inside compartment of the trailer. There is very little space to see or fit even my small hands in between bracket and TV, and it's hard to see if there is some release pin or thing. Any knowledge or experience is appreciated.
Thanks for the info "razntwn", it worked like a charm.
2013 T@B 320 CSS (purchased in 2018)
1997 & 2021 Toyota 4Runners
Northern California -
@grace - http://tab-rv.vanillacommunity.com/discussion/3549/how-to-remove-or-install-outdoor-television-cs-s-model
Thank you. IDK why that link was not working earlier today. Winds up, my television was installed a different way. Will post my own journey of discovery on the forum.2013 T@B 320 CSS (purchased in 2018)
@grace- many thread locator addresses contain the old “vanillaforums” instead of “vanillacommunity” in the thread address. If you ever come across this, reach out to a moderator and we can change it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
So thankful thus resource exists!! Bless you all who share info as it has really helped this new to me T@b 320 cs owner figure a lot of things out!!
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
