So I looked through the forum and didn't find this specifically addressed. Hopefully, one of you have seen this and can aim me the right direction. I feel confident that I understand how to use the Alde system with the 3010 digital control panel. The issue I'm having is that the hot water at normal (1) is practically non- existant. It seems to be lukewarm for about a minute. If I bump it to 2, which is supposed to be boost, I get plenty of hot water although not terribly hot (meaning I don't have to turn on ANY cold water to have it at a comfortable temperature). According to the manual, 1 is supposed to be 122 degrees and 2 is supposed to be 144. I haven't put a thermometer under it, but I'd venture that it's not - especially on 1.
I haven't adjusted the mixing valve, but that might be my next step. Unless someone has a better idea.
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
http://www.tab-rv.com/forum#/discussion/2676/little-hot-water/p1
Here in Colorado it can be hot during the day during summer but cool at night, 50-55F. I would get 'cool' hot water in the morning and 'hot' hot water in the evening. This is because the water in the fresh water tank would cool down significantly at night and was so cold it would saturate the hot water at the mixing valve in the morning. After warming up during the day it didn't cool down the hot water much at all.
Be careful, after adjusting the mixing valve the water is really, really hot! I mean... it's really, really hot!
No. The 3010 is the digital version of the thermostat. The top is heat, the 2nd is hot water. The 3rd is the one I'm referring to. If you push the + sign, it goes to 2 kw (I should have mentioned that) for a turbo boost but reverts to 1 kw after 30 minutes. With it pressed to 2 kw, the water gets moderately hot. That's why I do believe it makes sense that the mixing valve is too low. Doubling the kilowatts at the furnace does increase the heat of the water for the length of the time that it's running at 2 KW.
Anyway, thanks for the clarification, and the info about the digital panel. It sounds like the boost feature is the functional equivalent to the "three lightening bolt" setting on the analog panel. I agree that your case sounds like a mixing valve issue.
I'm pretty much a newb, so if I've got it wrong, I'm not gonna argue.
However, while more juice will heat the water more quickly, the actual temperature of the water is controlled by a thermostat, and should be the same regardless of how many elements are activated. I have not confirmed this personally (though I see an experiment in my future).
To further confound the matter, on the analog controller, the "hot water only" setting makes much hotter water than the "heat and hot water setting" (150F vs 130F). I have confirmed this personally. This feature sounds a bit like the hot water "boost" you describe with the digital panel.
The second with the shower icon selects hot water or extra hot water. This is the one that reverts to the default setting after a few minutes.
The third setting with the lightning bolt is for heating with electricity, off, one, or two electrical elements.
The fourth setting with the flame icon is for heating with propane, off or on.
You have the digital Alde control, right? There is a "secret" menu that might be useful in troubleshooting. From the main screen touch the wrench icon, then press the down arrow till you get to the Service and Reset screen. If you press Service you will see a screen that says Activated Functions, then press the down arrow one time. Now you should see the Heater Temp and Sanitary Temp (which is apparently the Swedish translation of Water Temp.)
If your Alde is functioning correctly you should surprisingly high numbers for both.
