How does the Ridgeline tow?
SystemSystem Posts: 186
edited October 2016 in Trailer & Towing
This discussion was created from comments split from: What battery should I upgrade to?.
  • RamrodRamrod Member Posts: 164
  • KBaggins1KBaggins1 Member Posts: 135
    We have a 2009 Pilot and if you are talking about the old Ridgeline , it has the same drivetrain as ours . The problem with these vehicles is a lack of torque in the low RPM range .Even towing a lightweight trailer like a T@B , going up any hill causes multiple downshifts and high revs and bad mileage .No hills no problem .The newer models should be better , direct injection drops the peak torque down 1000 rpm's .
