Hello.
I am looking for recommendations for the placement of a floor jack.
I need to raise the trailer for maintenance.
Jacking using the Torflex axle as a lift point is not recommended and I do not want to compromise the integrity of any of the chassis seal components that appear to be installed along the frame edges.
Suggestions are very much appreciated.
Thank you -
Mike
0 ·
Would this procedure be recommended as part of a long term storage procedure? I am told that jacking a trailer to raise the tires off the ground is advised for outdoor winter storage.
- Mike
(The alternative procedure described above by Dale is also in the manual in the section covering flat tire repair.)
