Tongue jack hight
RollingBnB
Member Posts: 322
How high is the tongue jack when the trailer is level. I need to pull it in under a shelf and will raise the shelf if I need to.
2020 Tiffin Open Road
2020 Nissan Versa Toad Alan & Patty
Southern Az
Nobody can measure the height of the jack ?
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
RollingBnB-36 inches for our outback modelJohn, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Do you mean pull it with your TV while trailer is level and jack handle is down?
Or pull the handles on the T@B to maneuver it into storage with jack handle down? (trailer doesn't need to be level)
Do you need to be able to crank the jack handle while under the shelf?2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
Tabberjohn, I just want to know the height of the top of the tongue jack when I go to store it. I want it level so I can run the appliances as if I was at a camp. Don't need to crank after it's in place.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
I think what he is asking is the same thing I would like to know. If the trailer is sitting level, how high would it be from the ground to the top of the hitch. I'm thinking somewhere between 18-24"?2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed -
On my std T@B it's 29.25" (crank hanging diwn) a Would be more on an Outback with the higher suspension.
Is that 29.25" to the top of the "jack" or to the top of the "hitch?"2022 T@B 400 BD
Outback is level, driveway drops 3/8 inch at jack wheel. Ground to top of jack is 35 inches in daylight, 36 inches in the dark!
I think I understand what you are asking, but the exact height of the crank (or the hitch) is difficult to measure accurately unless the T@B is parked on a perfectly level surface. Mine rarely is, but maybe somebody who parks in a garage can help you out.
29.25 from bottom of wheel (ground) to top of jack crank head.
PXLated said:29.25 from bottom of wheel (ground) to top of jack crank head.
Thanks, that's exactly what I needed
Alan & Patty
Southern Az -
Cool - Remember everyone, that's on my standard axel T@B, not the Outback.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
