Will Honda EU2000 fit on Outback front shelf?
LeslieandNorm
Member Posts: 17
Won't take delivery of our TAB MAX CS-S until Spring. Ordered it with the Outback shelf on the front. Will my EU2000 fit on the left side of the shelf? Does anyone know what the measurement is from the side of the propane/battery pod to the edge of the shelf? Excited waiting!!!!
Norm and Leslie. NJ. 2017 CS S. TV. JEEP Grand Cherokee
It must, seen threads where they're doing it - pics to.0
Facing the TAB from the front, you can put a square object 20" wide (left to right) by 14" deep (front to back).2016 Outback 320
Honda EU2000i = 20.2"L x 11.4"W x 16.7"H, Dry weight: 45 lbs2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0
And if you put a five gallon gas can on the other side that would be in the neighborhood of 35+ pounds.0
I have two 5 gallon plastic water jerry cans on one side of the Outback platform. One filled with tequila and the other vodka.2016 Outback 320
2024 Ford F150 Supercrew short bed.6 -
I know booze makes you light-headed but is it lighter or heavier than gas?0
Water is over 8 lbs. while gas is about 6lbs. Per gallon. Vodka weighs 8lbs. Per gallon. Since they weigh the same, better to carry vodka.2016 Outback 320
I've found that if you carry 5 gallons of vodka, you find little need for food, change of clothes, and other items of personal hygiene. Maps and other directional devices can also be left at home. And most importantly, you won't care about tongue weight (trailer's - not that thing in your mouth).2016 Outback 320
2024 Ford F150 Supercrew short bed.2 -
Thanks for all the input . I will check the effect on the tongue weight. Do you see that as a problem for my jeep grand Cherokee tv?Norm and Leslie. NJ. 2017 CS S. TV. JEEP Grand Cherokee0
What is the tongue weight rating for your TV?2016 Outback.....North East N.C...... Former 2012 Silver Shadow0
Where are you Outback AZ? I have 5 gal of tequila and I'll match your vodka. j/tSug@rsh@ck - 2016 Max S Outback, 2016 Nissan Pathfinder.0
Sign up for T@Bazona and I'm sure you can make that deal with Frank :-)0
Fits perfect... just towed over 1200 miles with no issues2016 T@B silver Sofitel/Outback combo, 2012 Jeep Wrangler Sport TV, Kernersville N.C.0 -
Thanks so much for the input and especially the pictures. Got the eu2000 yesterday. Plan was to have it on the platform with the locking plate I see the platform is too long to fit on the outback shelf. Maybe I can mount the security platform in front of the shelf on the toungue. Carry the gen in the tv and run it on the toungue/security plate with an extension on the exhaust.Norm and Leslie. NJ. 2017 CS S. TV. JEEP Grand Cherokee0
Can the tub be moved 4" toward passenger side to accomodate generator and platform on drivers side? Modify drivers side of tub to accomodate generator? It's just aluminum.2016 T@B MaxS, 2018 Jeep Rubicon 4dr, Rural Scottsdale, Az.0
http://www.perfectcasita.com/ho20semosy.htmlLowPro LockDown generator security system for Honda EU2000iItem#: sms-h2000Availability: Usually ships the next business dayRegular price: $229.95Sale price: $199.95, 2/$379.90
I had this welded to the front of my 2013 LG 5W in front of the tray and was never worried about losing my Honda Generator. I plan to weld one in front of the bucket on my new Tab too....unfortunately I won't have the tongue weight to carry it while towing. However, when I get to camp I'll leave locked on the Tab. Of course not while it's running....just in case any thinks it's a good idea to have a generator running under your window.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.1
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
