Small Clear Tubing Running Into/From the Fresh Water Tank Still has Water Visiable after Winterizing
I just finished winterizing for my second time, and I'm still seeing water inside a clear small diameter tube that feeds into the fresh water tank.  Does anyone know how to get this water out or does it not matter? I couldn't really get under there to take a photo.  I used the blow out method first, then I put 2 gallons of antifreeze in the fresh water holding tank and ran the water pump to distribute it through the system, but this clear line isn't being affected at all.   Any thoughts on how to clear this, or is it ok to just ignore it?  Thanks
