One last mod - cargo netting
Photomom
Member Posts: 2,217
One last mod before she goes to the storage place tomorrow.
My aluminum tub has lots of space but is open in the back so I've been leery of putting small items in there. This is a 20" by 24" cargo net from organized obie that I've bolted across the open area. I can keep my leveling blocks, stabilizing pads, and chocks here without fear of them falling out the back.
Pro tip: when drilling through the tub, be sure to put a piece of wood between the tub and propane tank or battery box as a stop for your drill bit!
Brilliant !! Your battery is 90 degrees rotated from mine... must look at that so I can copy you.Reformed tent campers now in Ab T@B - 2016 Outback
The dealer installed a group 27 for us because there was plenty of room in the aluminum tub. I originally thought of keeping the sewer hose in there but it came to my attention that some people think it's yucky to do stuff with the battery or propane tank if the hose is there.SteveW said:Brilliant !! Your battery is 90 degrees rotated from mine... must look at that so I can copy you.John and Henrietta, Late 2016 T@B S Max in Western New York -
I store my hose in the tube but would take it out if someone needed to work in there - So far, nobody ever has had to.
PXLated said:I store my hose in the tube but would take it out if someone needed to work in there - So far, nobody ever has had to.
I thought I had a leaky propane regulator and pulled the hose when I stopped at a dealer. That's the only time I had to pull it.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
jkjenn - Yep, nothin in there that needs any kind of regular maintence or getting at.
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
