As most know, I'm running pretty much stock with a Group-24 battery and am not going to do any great mods to accomodate a bigger battery or especially duals - The simple mod for a Group-27 via a simple battery frame insert is a possibility but I was intrigued by the fact that this Bluetop could just drop into the standard battery box - mentioned in another thread.
So, here's what I have...
And here's the Bluetop specs...
What would it buy me powerwise, if anything, to drop this in?
2014 T@B CS Maxx
Martha Lake, WA
Seattle, WA
Discharging batteries is entirely a function of your particular application.
However, below is list of helpful items:
Seattle, WA
What I gather from various posts is that the advantage of considerably more expensive batteries does not necessarily equate to more power, but rather offers some combination of the following:
- longer serviceable life
- better able to hold a resting charge
- maintenance free
- less susceptible to permanent damage from deep discharging (?)
Am I interpreting this correctly? It would be helpful to have a concise list of the pros and cons of various battery types with respect to our particular use. Thanks for any additional insights.
Name brand stuff may or may not actually have longer service life or quality control. There is a lot of anecdotal evidence out there for it, though. Trojan seems to have a good following on the internet.
The battery you buy will depend entirely on your needs. If you find you are short on power then you will need more capacity OR a charging solution (solar/generator), or both. If you currently do not run out of power then do not change a thing!
In my T@B, I have two 6-volt golf cart batteries that pair nicely with my 200 watt Zamp solar panel suitcase. During last winter in AZ, I do not recall going below 12.4V.
I knew a 80 watt Zamp suitcase was just enough for my "toys" with an Interstate 100ah AGM battery the winter before in my teardrop, so I decided to buy once for the next 10 years or more for my T@B and bought the 200 watt Zamp (I discussed my payback plans in another discussion last week).
While I'm not saying you must buy my brand of choice, do as your budget allows and maintain your equipment. Know what you need today and calculate your expected growth in usage.
Seattle, WA
Seattle, WA
The quoted battery is a Optima battery which is in the higher price range. They are not your standard Auto-Zone/Batteries Plus/Big Box Store battery. But yes, you can find some good deals on Trojans if you search around. I bought two Batteries-Plus 6v 230AH batteries for $109 each. Closest Trojan was $165 each. Will they last as long as the Trojans? I don't know, but I am sure I will get at least 5 years out of them
The Dish is one thing I splurged on and that was part of the reason I recommend assessing your own needs.
I prefer the 3-way fridge as it is a miser on propane, or my ARB fridge freezer that is just as miserly with 12V. No need for electric in the desert!
With golf cart batteries, and some good group 27s, you get a true deep cycle, with far thicker plates that can withstand more cycles. But they can cost more too, and you need to modify your camper to accommodate them.
It all boils down to your own usage habits and expectations. Pxl is perfectly fine with the stock group 24, and since he's conservative with his power use, has opportunity for solar, it is a good fit.
I'm my case, since I have a clamshell with the power hungry 12v only fridge and our cloudy weather up here (plus my love of deep forest camping), I found that 2 golf cart batteries work best. I can get 2 nights of camping, running the fridge, televisions and water pump, lights, etc, with no energy conserving habits at all, and still have 60 percent charge remaining. That fits my expectations and I was willing to put the expense and labor needed to make it work.
2014 T@B CS Maxx
Martha Lake, WA
As far as camping and boon docking a lot and using those 12 volts, yes, I'd agree that a higher AH capacity would likely be a better way to go.
I don't think we ever used our T@B enough to make much of a dent in that Optima, because we were generally somewhere where we could plug in or else our trips were only a day or two, so we never put that much of a strain on it. (And keep in mind that we had an older DM T@B: not much to drain the battery, just the occasional fridge fan, lights, and the CO detector.)
