All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
T@B Outback Ski Chalet
I have a brand new Outback that I intend to use in very cold conditions.  It will be stored in a heated garage connected to power during the week and parked at a ski resort for a night on weekends.  I have a couple of questions that I would like comments please.
1. If the water system is winterized, will the ALDE still work for heat.  I understand it has a glycol loop for heat but does the hot water heater need to have water in it for the system to work as a heater?
2. Any way to be able to use the FW, grey, and black systems without those freezing?  The Outback will be kept in a heated garage and towed up to the mountains with the ALDE heater on running on propane.
  • TabberJohn
    TabberJohn Member Posts: 588
    edited December 2016
    1. Yes. Heater works just fine winterized with the no water method.
    2. No because the Alde heat doesn't extend to the plumbing pipes or storage tanks. An extensive mod would be required and it's doubtful you could power it while towing at sub-freezing temps.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    What John said, the tanks and plumbing are on the exterior, under the cab, and not in the heated environment.
    Sterling, VA
  • Smullis7
    Smullis7 Member Posts: 221
    There is a thread on here about doing a modification to add heating pads to the exterior tanks, but you would still run into the issue of powering it.  It's worth a look though.
  • ChanW
    ChanW Member Posts: 3,165
    We made the effort to tow the Tab with the Alde on one winter, and it cooled right down inside, and froze the kitchen spigot, within 50 miles. Outdoor temp was probably 5° or 10° above zero.
    It was clear that it's not airtight, and it's only an inch of foam insulation wrapping.
  • TabberJohn
    Just dreaming but --
    Ideal solution would be a winterized T@B factory option that includes additional insulation and sealing plus a two zone Alde system.
    Zone 1 would utilize radiators for the cabin like it works now.
    Zone 2 would include heat transfer plates on the tanks and radiant tubing wrapped on all water pipes.
    Zones would be managed with circulating glycol from the Alde and a two zone thermostat.
    Top this off with a Zone 1 12v fan sucking heat from under driver's side couch and pushing it under wet bath floor into sink cabinet (someone did this mod). Or strategically placed radiant tubing tied to the Zone 2 controller.
    Thermostat setting for Zone 1 maintains the cabin heat at whatever temp you want (like digital thermostat works now).
    Zone 2 setting monitors the tanks/pipes and keeps them above freezing (automatic if enabled).
    One big IF here is a two zone Alde controller that runs glycol through each zone independently. If that were possible you'd have a system that takes care of all your heating requirements plus freeze protection. It would run on shore power continuously as needed or on propane and house battery for X days at a time.
    The extra insulation and sealing would support towing at sub-freezing temps.
  • Nomad
    Nomad Member Posts: 7,209
    And what would you expect to pay for that dream?
  • db_cooper
    db_cooper Member Posts: 748
    With RV antifreeze in the black tank you can get a weekend of toilet use out of the Outback no problem.  We just spent 4 days at Whistler using electric hookups but no water.  If it's just one or two nights you don't need a shower.
    I'm tempted to add heat pads and tape underneath, but it might not be worth the trouble.
  • TabberJohn
    If marketed as a 4 season factory option I imagine $1000 or more wouldn't be unreasonable depending on what's included.
  • Machak88
    Machak88 Member Posts: 160
    Agree with @db_cooper - we've done the same multiple times in temperatures dropping into 20ies and camped for 2-3 nights while in fully winterized state (no water hookup, only electricity connected). We bring on board a jug of water to be able to manually flush toilet bowl after use, and we have a separate small water conrainer with a spout for use on the kitchen sink. After we empty black / gray tank at the end of the weekend, we make sure to add RV antifreeze to both via all drains - that usually takes one full gallon of ready-to-use antifreeze. Never had a problem.
    2014 T@B S-Maxx with 2014 Hyundai Santa Fe Sport Turbo, Atlanta, GA.
  • Nomad
    Remember to make sure the antifreeze gets into the dump valves or they could freeze and crack.
