So, looking down on it, something like this: (fans attached to underside of shelf behind holes)ericnliz said:Why not place the fan(s) somewhere on the hinged lid installed so the air is forced upward [Toward the back side where the hinge is located would seem to be best], with enough excess wire to accommodate the lifting of the lid, and perhaps one at each end to help circulate the air better.
Yeah, with a seven-year old, covers would be important. I'm just not sure I want the vents showing from an aesthetic point of view. But, confetti is good.ericnliz said:You got it! Some kind of cover over the fans would be handy on the top side, like a speaker type cover to alleviate things falling into the fans. Of course if it's a holiday...confetti & a free party favor!
I may have to go sit in the camper and think about it some more. Could you provide a photo of the long hinged lid you are referring to?
What model/year T@B do you have?
Ah hah. Thanks!
For those interested you can add this type of info to your signature by clicking on your forum name in upper right corner, then Edit Profile button, then Signature Settings at bottom of list.
That way when you post something we'll know what model you have. You can also indicate your TV (tow vehicle).
LauraRey said:The heat exchanger is on the passenger side underneath the seat.
You sure about that?
We've got a main radiator in back under the shelf which circulates from the floor vent slots under the back couch, then a passenger bench radiator with in vent slot on the floor and heat out the top slot.
Thanks.. It all depends on your search words, thats for sure... I might go with the PXLated method... First off, I have a hole cutter that size, then, more heat distribution...OutbackAZ said:Search "heat vents for the rear deck."
