Moderator Note: Copied over from private messaging so can John gain the help from the whole group...
I have a 2015 Tab Max CS-S.  I can not get the heater to work.  I have awesome hot water, A full tank of propane with no fault light on the thermostat, good battery, 110 Volt source plugged in, and not.  Both glass fuses on top of the unit are good.  The 20 amp DC fuse is good in the other area.  It will not work on AC, or DC.  I disconnected both sources of electricity for a half hour, reconnected them, and still no heat.  The unit is plugged in under the seat.  The water tank is full ( if that matters).
In one of the threads, was said a possible broken wire from the controller to the unit, or a bad controller may be the problem or even a bad circuit board.
I live in Tulsa where the dealer sells truck accessories, and only has on occasion one T@B and one T@G trailer for his entire RV inventory.
May I possibly have one of the valves under the sink in the wrong position?  Is that possible?  The next nearest dealer is in Missouri, around 100 miles away.  Somehow I think there is a simple solution to fix this.  Can my local dealer (who I didn't buy it from) help me, or can I go to a local dealer who sells other brands help me.  If changing the controller on the wall is the most likely fix, I can probably change that myself.  Otherwise I can make an appointment in Missouri.
Do you have any other suggestions?
John / Tulsa, Oklahoma
(TulsaTime)
                0 ·
Also, have you checked the electrical outlet that the Alde is plugged into? Take a hairdryer or a power drill with cord and plug into the outlet. If your portable tool works, the outlet is good. If not, be sure to push the reset button the GFI outlet...and I'm not sure where the GFI outlet is in a CS.
Check underneath your T@B. One of the hoses that sticks down should have a brass plug in it. That's the glycol drain--if the plug is missing your glycol has likely parted ways with your Alde. If the glycol is completely gone I think there is a special procedure that needs to be done to bleed the system after refilling.
If you get it from Elsie at NuCamp, I think it's pre-mixed.
That's why I love this place!
Yes the drain plug was there behind the wheel directly below the Alde system
Thank you ALL for your help.
Joe
You might want to get that little mirror out and check the connection on the bottom of the glycol reservoir tank. The tanks have been known to crack there.
Don't drop your phone down there.
