Alde Display
redaunt
Member Posts: 31
2017 T@b Max S, Outback edition
We are going to be camping (2nd trip) the week of Christmas and will probably need heat and will definitely need hot water. Our hot water was **very** limited our first trip, but it was not very cold out so we were okay. This time around we are going to look at the Mixing Valve on the hot water/cold water to see if adjusting it helps (I read somewhere that this can be an issue).
But my question is about the Alde display/control panel that is mounted to the wall. Once you turn it on and set the parameters for heat / hot water, if you hit the "off" button in the lower left corner, does that turn the whole system off or just the display? Would love to be able to turn off the display at night and still have heat. Is there a way to do this?
It turns off the whole system. To turn off the display, you need to go into setting (click the button in the right corner). There is a setting in there that will turn off the display. I'm sorry, but I'm at work and can't remember exactly which one it is.Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
Bless you! I haven't explored that menu yet, but I'll look at it when I get home! THANKS!!!!
It is the Screen Brightness control. Alde manual, page 14.John and Henrietta, Late 2016 T@B S Max in Western New York0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
