Replacing stabilizing jacks with leveling jacks (Revisited)
Dalehelman
Member Posts: 2,414
How to install rear leveling jacks. With no modification to jacks or trailer. A simple adapter plate can be made from an 11" piece of 2"x 3/16 flat piece of steel from Home Depot.
The yellow circle measurement should be
5 1/4” not 5 3/4”
Tools required are a hack saw and drill with 7/16" drill bit. 3/8"x 1" carriage bolt. For the best fit the dome on the bolt can be filed or ground down flat.
- Hash T@B Fun
Nice description!!
BTW - Lowes (and other hardware stores) have "elevator bolts" which are a flat head version of "carriage bolts". Might save a little filing. Just FYI
Correct thanks for the input. Most people would not know what an elevator bolt is. Could not find them at Home Depot. Lowe's does carry a much larger selection.rfuss928 said:Nice description!!
BTW - Lowes (and other hardware stores) have "elevator bolts" which are a flat head version of "carriage bolts". Might save a little filing. Just FYI- Hash T@B Fun
I get drilling holes but, how do you get the square cut out for the "carriage bolt" or "elevator bolts"?2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
Use a square file or hammer to drive it home. Tightening it down with nut will also work. The adapter should be bolted to the jack first then bolted to trailer.dsatwork said:I get drilling holes but, how do you get the square cut out for the "carriage bolt" or "elevator bolts"?- Hash T@B Fun
Nice description on the install Dale! Now, back to the lawn chair & another cup of coffee for the next mod!
Eric aka: Lone Wolf1 -
You bet. This is an inside joke between ericnliz and I but true.ericnliz said:Nice description on the install Dale! Now, back to the lawn chair & another cup of coffee for the next mod!
- Hash T@B Fun
If I'm sitting by Eric i will be taking notes... :-)2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
I DO get mine in once in a while!
Dale, we may want to split this off to another discussion. But with all the mode you've done, I see you still have the tire mounted under the trailer. Have you considered a creating a skid plate for it? I'm going to need to leave mine in place and all the discussions seem to center around moving it because it drags potentially causing damage. Dave2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
In nearly 3 years and over 8000 miles I have never had any problem with the tire mounted underneath. I am mindful that it is there though. With storage at a premium I am pleased the builders mounted it there they did.dsatwork said:Dale, we may want to split this off to another discussion. But with all the mode you've done, I see you still have the tire mounted under the trailer. Have you considered a creating a skid plate for it? I'm going to need to leave mine in place and all the discussions seem to center around moving it because it drags potentially causing damage. Dave- Hash T@B Fun
Dale thanks that's good to know2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
Suggest you edit this post (like the original) to include a pic with jack closed so people can see how small that is.
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
Good idea
TabberJohn said:Suggest you edit this post (like the original) to include a pic with jack closed so people can see how small that is.- Hash T@B Fun
