Hey there,
We went to start our Alde system tonight and it  will run.  Plugged into shore power and propane is on.  Power and fuses all ok.....any ideas?
We've tried to open breakaway's new manual, but don't see a way to actually open or download it.  Help?  We are cold!
Thanks so much,
Marnee
                0 ·
We are pretty level in the driveway, propane is on. We turned lightning bolts to 3, gas on and thermostat to 5 and nothing happening
Thanks for any help...
Marnee
J.D. & Sue
I thought I had read in the manual not to turn on the hot water when tank is empty - but I think that is incorrect. I turned on that third slider to middle position per PXlated and we are gurgling away....
Thanks for all the help!
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
That's behaving like the fuse problem. It happened on shore power with mine.
There are two fuses, the old glass-tube type, on the Alde itself.
Look in the Yahoo Group / Files, "ALDE HIDDEN FUSES.pdf". Link is here, for the info:
https://groups.yahoo.com/neo/groups/tabtrailers/files/ALDE HEAT, HOT WATER UNIT/
Be sure all power is disconnected before working on it.
