Wheel bearing grease
sabel
sabel Member Posts: 283
edited January 2017 in Trailer & Towing
We have a 2015 Outback.
Had the bearings repacked, by a dealer, last spring. Does anyone know if there's a grease fitting anywhere or do you have to remove the wheels and bearings?
Thanks
    This discussion has some good info:
    http://www.tab-rv.com/forum#/discussion/3295/wheel-bearing-grease/p1
    There appears to be a fitting under a "rubber plug" in the "grease cap." I assume it's at the center of the wheel, but I've yet to take a look for myself. It's on the list to check out next season.
  • ChanW
    ChanW Member Posts: 3,171
    Yes, there's a zerk under a rubber plug, as Scott mentioned. And that thread that ScottG pointed to is pretty complete.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
