Jensen TV manual
Vegascacher
Member Posts: 27
Does anyone know where I can get a copy of the owners manual for the Jensen 19" tv? My new tab came with a quick reference guide with a QR code. When I scan the QR code it says "Requested file not available". Thanks for your help.
2017 Tab Max S (Silver/Black) 2013 Ford Edge
I'll check to see if a manual came with mine.Stancil Campbell
2011 T@B
Rockingham, NC
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)
I looked there but could not find one for the JTV19DC.TabberJohn said:
I've been all over the web and I can't find it.2017 Tab Max S (Silver/Black) 2013 Ford Edge -
Is that model number from the plate on the back of the TV? Or is the plate obscured by the mounting bracket?
2015 T@B Max S has a JE1912LED which is one of the entries at that site.
If I enter JE19 for a list of 19" models JE1914DVDC is listed at the bottom. Is that what you have?2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
I got the model number off the quick reference guide. Ill download the JE1914DVDC and see if that helps me out.2017 Tab Max S (Silver/Black) 2013 Ford Edge
Thanks it looks like that Manual will work. My model number is covered by the mount and you can't see it. I connected the tv to an antenna and got several channels but no sound. What d o i have to do to get the tv speakers to work?2017 Tab Max S (Silver/Black) 2013 Ford Edge
Figured it out. I'm no techie. The sound was turned off in the tv menu.2017 Tab Max S (Silver/Black) 2013 Ford Edge
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
