Yakima rack on the Outback
Has anyone carried a Kayak on the back of their Outback?  If so, did it affect how well the T@b tows?
Sally & Deb - Woodland Park, CO - 2017 T@B S Outback pulled by 2015 Toyota Tacoma.
  • T@BalongT@Balong Member Posts: 317
    I was told by PV that the preferred maximum weight limit on the back of the T@B was 100 pounds.  Between the Yakima rack and the spare tire, you would already be at about 70 pounds.   We carry our kayaks on top of our Jeep where I believe they are safer and more visible.
    States Visited Map
  • Sallybear5Sallybear5 Member Posts: 13
    Thank you Norm.  We would not put kayaks on with the tire but move tire to the front.  Just wondered if anyone had tried it.  Our kayaks are 35#. The kayaks fit in the back of our truck and we will probably continue to do so but we were also looking for more storage options.
  • iariversiarivers Member Posts: 11
    Was going to put ours on top of the Xterra; 17' kayaks won't fit on the back of the Outback
  • Tabaz Tabaz Member Posts: 2,382
    If you've ever driven your Outback over a rutted road, you come to appreciate how little suspension the trailer has.  It is brutal.  Anything on that Yakima rack is going to be subject to a lot of stress.  Better to keep it light up there.
  • db_cooperdb_cooper Member Posts: 739
    It is certainly bouncy so we keep it light.  No issues so far with our fork mounted bike racks, no damage to bikes or rack over a few thousand miles.  Bikes are both under 30 lbs each, would be hard to lift a heavier bike up there.
    I'd be afraid even small whitewater kayaks would be tough to secure.
    I don't recall anyone on the forum using the Yakima rack as creatively as DB. Kudos to him for taking the risk for the rest of us.
