So, now that I have a new TV I am looking to get out for some camping this weekend.  We were thinking of just dry camping at a nearby winery.  Even though it is 77° today, the overnight low on Saturday is predicted to be 27°.
I don't know that I have used the furnace in about three years, so went to test it this morning.   My 2012 has a CoolCat and an Atwood furnace.
Per the instructions, you run the fan without gas for five minutes, turn it off, turn on the gas, and then turn it on again and it should kick in in about thirty seconds.  I set the Dometic thermostat to Furnace to turn it on and instead the CoolCat comes on in fan mode.  Nothing from the furnace at all.
Anyone know what the problem may be?
Sterling, VA
0 ·
Sterling, VA
2012 LG T@B towed with 2004 Suburban
2011 T@B
Rockingham, NC
You might have already fixed the problem and it was something else. I just wanted to let you know that it might have done a reset and needed its fuse taken out and put back in, even though the fuse was (and still is) good.
