Can anyone suggest a flat screen TV mount?
I own a 2008 T@B Dutchman and I am removing the small AC TV and replacing with a 16" flat screen AC/DC and will mount somewhere between left window and closet.  I have seen many different wall mounts, some articulating and some not. Anyone installed a TV wall mount?
2008 T@B Dutchman, 2004 Hyundai Santa Fe, Grand Junction, CO.
"We Are T@Bulous!"
  • tabulous
    tabulous Member Posts: 13
    Thanks ST_Bob! Those are some great choices. Of course, I will have to wait until my flat-screen arrives so that I can evaluate the mounting capability on the back of the unit.
    "We Are T@Bulous!"
  • jkjenn
    jkjenn Member Posts: 6,425
    @tabulous Did you happen to find a mount you like? Mine seems to have broken on the way home (and broke the TV along with it.)
  • Spruce1
    Spruce1 Member Posts: 100
    http://www.parts-express.com/dayton-audio-shadow-mount-lcdart-articulating-arm-tv-wall-mount-up-to-30-lcd--182-370
    This is is the mount I installed to replace the factory mount.  It works great.  It's well constructed and was easy to install. The original mount kept coming loose and the television fell a couple of times.  The tv still works though after I resoldered the antenna jack.
    2014 T@B-S
    2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
    Minnesota
  • jkjenn
    Thanks! I think I found a similar one from Amazon.
