I was stunned to learn today that my old, decrepit, Honda 1000i generator actually ran the A/C in my 2016 Outback. It also runs my Westinghouse 600W microwave (not at the same time obviously). I was told by many that nothing below a 2,000 watt would run the A/C.
0 ·
I looked in my manual for the T@B and the Frigidaire manual and installation don't have any specs. I went to Fridigaire website, and looked at the 5000 BTU model FFRA0511R1:
Electrical Specifications
- Amps (Cool): 4.0
- Watts (Cool): 450
http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRA0511R1/Is this what would be installed in 2013 T@B Maxx?
If it's only 4 Amps and 450 Watts, then a generator rated at 1000 Watts would power it.
What am I missing?
Seems to be possible.
Will have to run my own experiments unless @OutbackAZ has data?
Hard/soft start kits can be bought inexpensively and added to the AC yourself, but you need to remove the AC from your RV and disassemble it to install. You might need to call the manufacturer to get the right part number too.
The startup surge rating can sometimes be found on the label, listed as LRA (locked rotor amps). It's optional info provided by the manufacturer so you don't always find it. As long as your generator meets or exceeds this, you'll be fine. Keep in mind too that higher altitude reduces your generator's output somewhat.
If you have an inverter generator, it's all but impossible to damage your AC if it's underpowered. The worst that can happen is it will trip after a second or 2. The real damage happens when your el-cheapo generator has insufficient power to start it up, and it just sits there trying to start for several seconds while the generator is struggling almost to a stall. It can potentially burn out the AC motor windings over time!
I bought one of those super cheapo 1400w generators on a black Friday sale, and I'm planning to test it out this summer. My expectations are low but it would be a nice bonus if it works.
2014 T@B CS Maxx
Martha Lake, WA
Betting these are stock AC units without the kit though.
Tim & Jill
2014 T@B CS Maxx
Martha Lake, WA
2014 T@B CS Maxx
Martha Lake, WA
It lugged momentarily to start it, not more than half a second, and off it went.
This generator will run for about 10 hours at half load, and the A/C is less than that, so I'd figure about 1 gallon will yield maybe 8 hours runtime with it's 1.3 or so gallon tank.
The generator is a Champion 1400w/1800w that I bought from Tractor Supply for $150 on a black Friday sale. They normally go for $200. Amazon sells the identical 1200w model for around $220 I think, which is basically the same generator.
Being a super cheap generator, it's not capable of reaching its rated power unfortunately. I can get 1000w reliably, but once you get to 1100w and up it starts to lug badly and the voltage drops fast. I figured this into the purchase, so $150 for a solid 1000w generator is a steal in my book!
Other downsides is it is louder than a Honda 1000. Put it where the sound won't bother others too much. It's also heavier but I can still carry it fine. It is an open frame style generator. The fit / finish / quality is impressive for this price range. It looks well assembled.
I performed the test at sea level, and I don't know if it can do the same at higher altitude, say 5000 or above. I plan to test it when I get the chance in the future.
2014 T@B CS Maxx
Martha Lake, WA
Will it handle a toaster? My Honda kicks into high gear the minute I drop the bread.
Is it quiet enough to meet the dBs National Parks and some other campgrounds have. One of the reasons I bought the Honda.
Let me research the DB rating & get back to ya.
2014 T@B CS Maxx
Martha Lake, WA
A forum on the Yosemite site mentioned 68 db/25 feet. Another one at Assateague Island National Seashore Park says 60 db / 50 feet.
This generator is rated 65 db / 25 feet, so this easily meets both minimums.
However, if you're someone accustomed to the small size and quietness of a Honda or Yamaha, you'll probably find this generator repulsive. It's not obnoxiously loud, but it's definitely no Honda. It's also larger / heavier in size though it's manageable. It takes two hands and a strong (ish?) back to muscle it. It weighs 60 lbs fully gassed up.
Just depends on how much you want to spend, and perhaps how much you camp. As an occasional camper myself (just a half dozen or so times a year), I can put up with it. Plus we use it at home to power the fridge & freezer in case of a long power outage.
2014 T@B CS Maxx
Martha Lake, WA
