i am preparing to pick up my tab next week purchased from a private seller out of state.  I had a hitch installed with a standard 7 pin connector. And a brake controller. My question is will this setup charge the tab battery as I drive.
Tv 2016 Kia Sorento 6 AWD
Thanks
Mickey
                Mickey & Terri
2016 Max S
Kalamazoo Michigan
0 ·
2016 Max S
Kalamazoo Michigan
CURT 58270 12V LED Connector Tester
(sorry, I could not post the picture.)
As has been mentioned -- ask previous owner and get a tester.
2011 T@B
Rockingham, NC
It goes from the battery to the 7-pin with an inline fuse, and should also run through a switched circuit so that it doesn't pull from the vehicle battery with the ignition off.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
How would you check if you have your charge line on a switched circuit?
I'm not Carol, but if you have a multi-meter or volt/ohm meter, you can check for voltage inside your 7-pin connector when your tow vehicle is not running. If no voltage, then your vehicle has a switched circuit that turns off any auxiliary power when the vehicle ignition is turned off. My Toyota Tacoma has a built-in switched circuit on all accessories.
Is yours a factory tow package package or after market? Factory--it should be off when the ignition is off. After market--check it.
Yes, the tester will verify power. Check it.
From what I understand, some installed charge lines are not heavy gauge, unless you specify that you want it. The Tab needs it, due to the heavy draw of the three-way fridge when it's running on 12v.
