Sleeping arrangements
webers3
Member Posts: 436
Not knowing the width of the seating bench, can it be used comfortably as a twin size bed, ie: without making up the bed?
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
It is pretty narrow. Maybe for a child. Just measured: 20.5 inches wideRed and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!0
There's some really good photos on the forum of different ways other owners have configured their T@Bs for twin beds. If you do a search for twin beds, I'm sure photomom's link and others will come up.Verna, Columbus, IN
My first look inside a T@B was an older Gentlemans rig. He had tossed the bulky table and used a floor pedastal and a small round top. He had 1 8" wide slat at the rear of the "U" and had his bed set up perpendicular or left to right.0
I detached the bottom and back cushions from each other. When you remove the back cushion, it is the size of a cot, which works well enough for me if another person is along.Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
Hmm... in looking at the schematic, you'd have to drop the back bench to get proper length. Once that's dropped, unless maybe it is a mobility issue, I think you might be better off turning sideways and sleeping wheel to wheel which I think is around 70"x40" and would give you twice the width.
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
I'm a very visual person - don't get me started on pie charts verses bar charts!
