Solar panels
Alski
Member Posts: 1
I have a Coleman hundred watt solar panel and wondering if it's connected directly to the batteries if I put a charger on the batteries will the power from the charger affect the solar panel?
Eric, maybe it is cloudy and the solar iSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
If you roof mount a panel and roll on down the road you are using 2 sources simultaneously to charge the battery. Your charge controller prevents overcharge- don't think it is a problem.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I have 100w mppt set up on my vanagon and hardwired 20amp marine charger into the shore power system. It gets plugged in after every trip and after 2 years....no problems other than healthy batteries.0
It shouldn't impact the panel if the voltage is within 12-14 volts DC. You basically do the same thing when the vehicle is running and have fixed panels on a trailer and this is why we install fuses on devices to protect against high voltage or surge type conditions. For peace of mind I'm sure you could easily install a small disconnect switch for travel time if this were a concern.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
