Fresh Water Fill
When I connect to city water, does the water go through the fresh water tank and fill it or does the fresh water tank have to be filled separately?
2017 T@B S
    Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
    monamona Member Posts: 241
    The tank has to be filled separately.
    Jeannie
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
    newellnewell Member Posts: 182
    Thanks Jeannie.  I'm sure there is a good reason but I can't think of one....
    There is a need for the pump to pump water from the fresh water tank. The city water uses the pressure from the city water to pump the water through the pipes, so you don't need a pump when using city water.
    I understand that the city water goes in under pressure and that the water in the fresh water tank needs to be pumped.  Okay, why can't the city water on the way in (under pressure) fill the fresh water tank along the way just as the cold water, city or otherwise fills the hot water tank on the way?
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,528
    newell - the pump is positioned between the tank and the city water connection.  The pump only flows one way - back check valve?  Here is a diagram.
    wizard1880wizard1880 Member Posts: 442
    Some RVs have this option.  You could plumb it in if you really wanted to.  Basically, there's a valve near the tank that will pass city water into your tank.  I've only seen it on Class As.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
    edited May 2017
    Even if it were possible you'd want control over it. Otherwise the fresh water tank would get filled every time you hooked up to city water. That's 100 lbs of water you may not want to travel with.
    Yup, they're manual control.
    It would sure make the winterizing / flushing process easier!
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
    Good point TabberJohn, carrying 110 lbs. of water isn't always necessary.
    Sam, great diagram.  Thanks for that....newell
