Now that I'm in warmer temps I'm ready to fire up the onboard water but since I boondock a lot you can never have enough water. I was hauling two 2.5gal jugs set on the shower floor but they'd need to be removed if I wanted to use the facilities. But, but, what's that little ledge on the outside wall doing there just wasting space and forlornly looking for a purpose. Ahhhhh, smaller water jugs (see pic).
Command picture hanger velcrow on the backsides seem to hold them fairly tightly against the sidewall. May have to add a bungie across the front - will see how they hold while traveling.
Walloe - That's also an option.
Those jugs look perfect. Might even grab a few more for the back of the pickup.
We've been using maple syrup bottles. Easier to pack square bottles.
Thanks for sharing.
Traveled 100 miles and found this when setting up (see pic).
Gonna try a couple of hooks and a bungie cord - or figure out how to hold the curtain rod in place - obviously the tension alone didn't do it.
I'm determined to get them to stay on the ledge. I just hate having to move things around when traveling :-)
Just wondering if this is still working for you? Thank You
(9/22/19/
