I'd like to be able to cut off all power to my 2007 DM T@B while I sleep at night. Would I do that with the breaker switches under the driver's side seat? Or some other way other than unplugging? Thanks in advance.
Katt and Miss Cannoli the Zen Dog
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny"
0 ·
You will also need to disconnect your battery, as it will continue to provide 12V power after shore power is disconnected.
One caveat...on my 2015, the CO/propane detector is hard wired. No power = no detector. Not sure how the 2007's were configured.
However, if I were going to do that on a daily basis, I'd install a second cutoff (or relocate the existing one) inside next to the converter.
(Again, I'm basing this on the wiring configuration of my 2015, but I suspect yours is not much different.)
