Hi,
I just wanted to post a picture of what you have when you remove the shower floor.  I had a crack in the shower pan of 2015 T@B Max S I purchased this spring and decided to fix it right by replacing the floor.  Feel free to ask any questions about the replacement.  Easier than going in blind like I did.
Matt
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
Yes, there was only 2 one inch chucks of styrofoam for support next to the shower drain pipe. I framed a new floor in there to firm it up. Still plan on using a wood mat of sorts for protection though.
The 1 to 5 scale...for me was in the middle. Pulled one side of paneling off. There is access to the shower trap underneath. It unscrewed. The toilet flange is threaded and screwed in so that is good to know. Cut the caulking and tap it with a cold chisel and it will start to turn.
Hope that helps!
