CS- Bedding storage?
gophergrad
Member Posts: 115
I note that most people seem to store their bedding under the back bench, but the CS doesn't have one. The passenger side bench has bed slats, tools, hockey wheel, chicks, etc. The driver's side bench has a lot of T@b guts already in there. So.... where do CS peeps hide the bedding?
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky
We store our bedding under the pass. side bench. Our '15 CS has two "slats" that match the table top...we slide those to the back and use them as extra table storage. It makes the small side door sorta useless.
Would love to hear other thoughts.
We create an 18 inch area with the provided slats at the rear of the TaB and fold the bedding up so that it lays across the slats and far areas of the benches. Most times, We are outside, in the tent, or under a canopy and we do not need the inside until bedtime. The Lagun is outside, too. Our bedding is pretty limited - no foam pad, only a duvet covered mattress pad and a duvet covered quilt.
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2 -
We roll our mattress topper with the bedding and pillows to the rear also. The big roll mostly holds itself in place under the rear cabinets. With the table up it becomes trapped. The DM cushions are split lengthwise so there is four sections on each side. We always leave the back half in the bed configuration. Just the front half of each side changes from seating to bed.
We find we can lounge lengthwise on either side of the table using the bed roll as a backrest.
The change from bed to table and back is quick and easy.
2 -
Lately we have been camping when it is convenient to leave the bed made up with a heavy mattress pad and a set of short queen sheets. But our final trip for the year predicted cold weather and rain requiring hanging out inside our CSS TaB. So, we returned to using a duvet covered mattress pad. I found a new place to store it during travel or during the day.
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio3 -
Like many others, we've got a 2" mattress topper wrapped in a duvet that I made some nylon straps for. We've only done one outing so far, but it worked out really well!
2020 T@B 320 CS-S "Salty Pearl"2015 Ford F-150 5.0 4X4 "Walter"St. Augustine, FL1
