CS under sink shelving
Sharon_is_SAM
Member Posts: 10,035
We continue to arrange our new TaB. My DH installed these shelves under our galley sink. We were worried about damaging the plumbing lines. He only had to cut out a small piece of shelf to make everything fit. Used a command hook to keep it from drifting into the back. Plan to use a part of another wire shelf to cordon off the back. You can change the height of the shelves on the right, too.
https://www.amazon.com/Grayline-40916-Adjustable-Cabinet-Helper/dp/B008SEYD1C/ref=sr_1_18?ie=UTF8&qid=1495413494&sr=8-18&keywords=grayline+shelves
https://www.amazon.com/Grayline-40909-Adjustable-Cabinet-Helper/dp/B008SEYA0Q/ref=sr_1_1?ie=UTF8&qid=1495413580&sr=8-1&keywords=grayline+40909+shelves
4
That's an interesting approach. This is what we did in ours. Now granted, this was after we had the sink removed, but I think it would still work with the sink installed.
John & Lori in Northern VA
Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B"
2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"0 -
I'm a fellow CS owner & we had the same concerns. Here's what we came up with. We initially used the tension rods but ended up putting in a small board attached with L brackets (not pictured). Also used cut pool noodles in back to keep bins from sliding back and hitting plumbing. I only put soft stuff (towels, tablecloth) on wire shelf during travel.
2017 T@B CS-S Max White with Plum Metallic towed by 2019 BMW X30 -
More detail of foam behind bins. Also bins can come out and sit on counter at camp.
I have been using very firm foam, but I like the pool noodle idea.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Great mods!Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
at this time of year pick up some kneeling garden pads, great stuffers also, hubby and I have a 2017T@G MAX xl, used in the galley behind the containers in the upper shelf (blue pads -
stops the jiggle), also used some below our kitchen sink also Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
Thanks to all for the clamshell specific mods!
It's nice to see everyone's different approaches. This is another area that I think I will have to pay some attention to, in order to use the space most effectively.
2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada1 -
Yes, the CS model has the most storage options.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
