Group 31 Battery
Has anyone installed an Interstate Group 31M AGM battery in their T@B and with what results?  In the standard front storage compartment, it would have to installed without the battery box, which after I described the T@B front storage compartment, he said he would have no problem installing an AGM battery under those conditions.
States Visited Map
    How many Ah in that group 31?  Have you considered putting in two 6's?
    J.D. & Sue
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,053
    Tabalong, our TaB build order specified accommodation for our large Lifeline 150 amp AGM installed by the dealer.  The factory was able to weld a new support bracket and created a custom aluminum box as no battery box would fit.  The tub was pulled away from the trailer, so we have a large gap, but the AGM fits nicely.  If they are willing to weld new brackets, or mount the battery on top of a wood frame on the current bracket, it will work.
