Just got back from a 6 week trip out west with our new T@B max S model. At least had 6 nights of temps in the low 20's. In the past, we had motorhomes with the fresh water tank inside, so just had to add some antifreeze to the gray and black tank, one motorhome had heated tank pads. The T@B tanks, including the fresh water tank are all outside. I;m looking at installing a heat pad on the freshwater tank, gray tank and black tank, which are thermostat controlled. Also, plan to install a pipe pad on the gray water drain pipe and black water drain pipe. These will all work off the battery, but I plan to use them, when plugged in at the campground site. Which means the converter will be handling the load. My concern, is if the converter in the T@B unit will handle the additional load of the pads. I have not talked to the factory yet. Just curious if anyone has installed heat pads on their tanks?
Thanks,
Jeff
1 ·
The new setup provides about 1/2 inch more ground clearance as compared to the previous gray water outlet and is easily accessible with the platform loaded. I utilized a cable operated valve for the gray water so that I could mount the valve near the gray tank reducing the amount of plumbing to worry about freeze protection.
Just a thought.
In our 2014 'S' model, looking under the driver-side bench seat, you can see an opening that goes 'under' the shower, toward the front, through which all the plumbing and electrical is routed.
It's pretty warm under that seat while the Alde is going, and I've been known to set a little 12V computer-type fan in there to blow heat through the tunnel under the shower.
This warm air ends up in the forward wall cavity where the pump is, and into the cabinet where the kitchen sink plumbing is.
I've never installed it permanently, I just have it wired to a cigarette-lighter type of plug, but it might be a good addition.
My design is split into 5 zones with a master thermostat under the trailer set at 35 degrees and off at 45 degrees. Each zone can be turned off manually when not needed (i.e. no water in gray/black etc).
1) Fresh Water Tank: 4.1 Amps Max
Tank heater has an additional builtin thermostat that activates at 44 degrees and deactivates at 64 degrees.
2) Fresh Water Pipe: 3.0 Amps Max
Fresh water pipe is protected by a self-regulating heat cable attached to the PEX pipe and insulated with rubber insulation approved for heat cable. The cables current draw decreases as the cables temperature rises allowing it to adjust current draw automatically as required by the conditions. This also allows it's use on the PEX pipe in our trailers.
3) Gray Tank/Pipe: 8.2 Amps Max
Only used when gray water is present (generally not when traveling). Same thermostat design as above.
4) Black Water Tank/Pipe: 1.8 Amps
Only used when black water is present (generally not when traveling). Just heating the 3 inch pipe space outside the trailer as the black tank is in the heated space of the trailer and the heat from the pipe will rise into the tank area.
5) Gray/Black Valves: 5.5 Amps
Valve heat is only needed if a thank valve is frozen closed. The valves themselves will not be damaged by freezing as long as the adjacent pipe is protected from freezing.
The Max current draw with liquid in all tanks (valve heat not on) is approximately 17 amps. However this current draw would typically only be used while plugged into 120 volts and the current will typically be less based on the thermostats within the pads etc. A typical driving down the road current will be something less than 7 amps (just fresh water).
We will see how it all works out in reality. I appreciate any ideas people may have.
1. Upgraded batteries
2. Combined Gray & Black into single discharge point
3. Added UltraHeat Tank Heaters to Fresh & Gray Tank/Gray Pipe Heater/Black Pipe Heater/Valve Heaters
4. Added TraceHeat Cable to Fresh Water pipe under trailer
5. Upgraded Converter so that dual batteries will be charged faster
6. Upgraded wire size between batteries and converter to handle additional current
7. Added Trimetric Battery Monitor for real time battery status
The actual current draw is less than I described above. Heading out tomorrow for some rain camping (Pacific Northwest) but no cold weather in the immediate future so I won't be able to report on actual freeze protection (actual current draw while freezing/overnight) just yet.
