How to install A/C vent cover?
@hymie best idea I've seen yet for an A/C vent cover. Joseph Langrek on fb t@b group nailed it. I just boaght the material for that idea! Going to build one and will post pics of the results here when done. Thanks for sharing!1
Just wanted to follow up on my earlier conversation. As I said earlier, I used Duralock to attach the cover to the outside grill by placing long strips on the top and bottom and short strips on the sides, but the strips being long enough to cover from snap to snap. After traveling in it over the past several weeks (one trip through the Owyhee byway with lots of bumps, dirt roads, etc. and my most recent trip in pouring rain, severe head and side winds through the desert between the Hagerman Valley and Boise), the cover didn't move an inch. I have also washed the trailer several times and noted no water intrusion. At this point, I feel comfortable saying it will work well. As I noted before, if you use Duralock, it is expensive. You also have to thoroughly clean the cover and the grill with alcohol prior to applying or it won't stick. Finally, I have not tested its retention by putting it on, taking it off, putting it back on, etc., but it seems like it will hold.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed0 -
I loved this idea so much, I copied the concept (with some modification). Heres what I have so far! Will post pics when finished hopefully this weekend!
Thanks for the GREAT IDEA! It will match the diamond plate rock guard and the custom tongue box I copied from the teardrop shop website but made it much better! Pics soon!
hymie said:Posted in another thread but deserves to be here...
Credit to Joseph Langrek on fb t@b group!
I will be doing something very, very similar to this! Looks great.
2 -
Where did you buy snap on cover ? I want to order one Thank you
Where can you order the metal vent cover ?0
@Talan, The snap-on version can be ordered through the parts department.
Toll-Free Number: 844.823.9112
Phone: (330) 852-4811 Ask for parts, or use extension #304 for Elsie
The metal vent cover was made by a forum member, can't just be ordered.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
@JohnDanielsCPA Any further report on the 3M product? Still stuck on there? Thanks2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky0 -
Nice vent cover!Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
The cover is still attached after another weekend bouncing around in the dirt. Washed it all down when I got home. The 3M duralock continues to hold.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed1
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
