I see there are a few Frontier drivers out there, hope someone can help. I have a 2012, 2wd, V6, 6 spd manual. On the trailer plug there is no 12 volt power. Everything else works (lights). If I go to the brown relay behind the passenger kick panel and use a jumper wire for the 12 volts, then I have the 12 volts at the trailer plug. Anyone know why the relay isn't activating? I haven't been able to find any bad fuses and I don't have a repair manual.
T@B trip wherever
New surprises everyday
See beautiful world
0 ·
Relays can go bad, but the last one I remember replacing was a starter relay on a 1980.
Not much help, I know, but I am curious as to what the problem is and how to fix it.
See beautiful world
So, I'm still not much help. I'll poke around some more if I get the chance, as post back if any bright ideas surface. Please let me know if you figure something out in the meantime.
This shows trailer relay 2 going through fuse 38.
This shows a trailer tow relay going through the light switch. I didn't want that, so I concentrated on the one above that shows fuse 38 with 12 volts, which is what I'm missing.
This shows me where fuse 38 is and tells me it is fuse F16.
Finally, here is F16, the red one at the end of the test probe. You might make out on the cover it says TTow reverse lamp. See? Clear as mud.
The fuse panel behind the glovebox door has a fuse puller and spare fuse.
See beautiful world
In addition to F16, I also notice F4 (another 10A) is labelled "TRAILER TOW." There's also a 30A fusible link further forward in the same box labelled "TRAILER TOW." Further complicating matters, there are several trailer-related relays and whatnot in the box just in front of the one in your photo.
Not that I'm sure what any of these mean, but it does raise the question of which plug pin you are lacking power at. On mine, the center pin is the one that feeds power to the reverse lights, if your trailer is so equipped. The 12V feed that charges the battery comes through the pin at ~1:00. That's a different circuit all together, but may be related to those "Trailer Tow" fuses.
Just guessin'--I agree it's clear as mud. Do you have a link to where you found those wiring diagrams? Now I'd really like to know how it all fits together.
See beautiful world
Either way, I'm glad you got it resolved (and hope it stays that way), and I got to learn a few things about my own truck. Thanks for the link to the diagrams.
