Rear Shelf Mod in 2017 Outback Max S
Smullis7
Member Posts: 221
I finally completed the mod of my rear shelf to divide it into 3 sections for easier opening. This allows me to access the section I need without having to clear the entire shelf to do it.
The list of materials is:
1.5 X 1" metal hinges - 6 ea.
60 grit sand paper
1/16" drill bit...and drill
table saw
phillips head screwdriver or Phillips bit for a drill
wood putty in natural pine
light
level
and something to hold the back of the shelf sections at the correct height (we ended up with 2 iPhones and a square box of Kleenex....it worked)
The shelf is 54", so each section was cut at 18". The hinges were mounted at 4.5" from each side (2 hinges on each section). The screw locations were marked and pilot holes drilled before attaching the hinges. I sanded the cut edges and filled the old hinge holes with wood putty. In the Outback, we set the shelves to allow an equal gap on both sides (exactly the width of the key ring holding my T@B keys from each side, then centered the middle shelf. After piling the cell phones and Kleenex in each section and checking for level, we marked the hinge holes, drilled a starter hole and connected them. Done!
60 grit sand paper
table saw
light
level
Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
Very nice, love it.
Very well done! I like this mod.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
This mod is such a good idea... @dsatwork did the same on our 2017 T@B S and it makes it much easier to access each section...great job!
Living in our Airstream, traveling in our 2017 T@B Basic S
Married to Dave-aka, ds@work -
Beautiful!
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart) -
I did this same mod and am very satisfied. This should be a factory change. The only thing I did differently is that I hold the shelf doors open with magnets. Much easier, doesn't take up any storage room, and works great.
drpprmt said:I did this same mod and am very satisfied. This should be a factory change. The only thing I did differently is that I hold the shelf doors open with magnets. Much easier, doesn't take up any storage room, and works great.
Hmm...the magnets should interesting. Can you post how you did that? I currently don't have anything holding them open...the was the level wedged in there for show. :-)Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
