 sabel
                    Member Posts: 283
sabel
                    Member Posts: 283
            Any recommendations on showering?
The new T@B S is only equipped with a 5 gal. fresh water tank, has anyone actually tried taking a shower while boondocking? Is the Alde hot water tank enough?
We were wondering if you could only use the shower while on shore water.
Thanks
I have used the shower while boondocking, and I am guessing PXLated has done this more than me. I try to rinse up, turn the water off, lather up hair and body, and then rinse off. You will blow through water and grey tank quickly when showering. Depending on the length of your stay, if you are extremely conservative, you could probably squeeze 2-3 showers out of it, depending on the length of your hair. They key, of showering is a priority, is to try to avoid using the kitchen sink. Use paper. I'm also try to use body wipes for hygiene between showers. If you had extra water and a portable waste tank, you could, theoretically, do this as long as your battery would last. Although, even with a portable waste tank, if you have to take it to a dump station, lifting into your TV could be hard, due to weight.
I will be curious to hear what PXLated says.
I just took on water yesterday but am in a campground with showers so probably won't try it until I hit the boonies again.
Since I have no hair (all I need is a buffing rag) - It's my personal water conservation program ;-)
2014 T@B CS Maxx
Martha Lake, WA
Unless of course, you were to take your shower lying down, somehow below the level of the Alde tank, and use gravity...
I timed it once, to see just how much actual shower time I could get out of a freshly filled tank. I believe it was a full five minutes of warm running water, which really is a pretty long shower!
I think the Alde 'tank' should be thought of more like a 2½ gallon water jacket, and that the water is heated 'on demand', as it's used. Wizard, I wonder if yours would have kept up better, in your test, if you were using 110V together with propane? Does the clamshell have the same size freshwater tank as the 'S', ie: 5gal?
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
There's a little red dial on the Alde - Hard to see as it sits sideways - I used a mirror. It has something to do with either temp or at what glycol temp the Alde cycles on off. There's setting like that on traditional house thermostats.
2014 T@B CS Maxx
Martha Lake, WA
2014 T@B CS Maxx
Martha Lake, WA
2014 T@B CS Maxx
Martha Lake, WA
2014 T@B CS Maxx
Martha Lake, WA
